1993 Audi S4
[insert_php] if ( function_exists(‘yoast_breadcrumb’) ) {yoast_breadcrumb(‘ ‘,’ ‘); } [/insert_php]
1993 Audi S4 |
Colors and Available Options | |
Available Options: |
Available Exterior Colors: | n/a |
Technical Specs | |
Engine/Engine Design | |
Type: | 2.2 liter, 20 valve, turbo-charged, 5-cylinder, in-line, electronic turbo-boost control. |
Bore: | 3.19 in. |
Stroke: | 3.40 in. |
Displacement: | 136 cu. in. |
Compression Ratio: | 9.3:1 |
Horsepower (SAE Net): | 227 @ 5900 rpm |
Torque: | 258 @ 1950 rpm |
Cylinder block: | Cast Iron |
Crankshaft: | n/a |
Cylinder head: | Aluminum alloy |
Valve Train: | Belt driven, hydraulic lifters |
Firing Order: | 1-2-4-5-3 |
Cooling System: | Water-cooled, thermostatically controlled electric fan |
Fuel/Ignition System: | Bosch Motronic electronic fully adaptive sequential fuel injection/ignition system, hot-wire air mass sensor, fault memory, dual knock sensors, |
Drivetrain | |
Type: | Quattro all-wheel drive |
Transmission: | 5-speed manual transmission |
Gear Ratios: 1st 2nd 3rd 4th 5th Reverse Final Drive |
Manual 3.50:1 1.89:1 1.23:1 0.99:1 0.73:1 4.11:1 n/a |
Steering | |
Type: | Rack & pinion, power assisted |
Ratio: | n/a |
Turns (lock-to-lock): | n/a |
Turning circle (curb-to-curb): | n/a |
Suspension | |
Front: | Coil spring/shock absorber (gas charged) struts, lower control arms, stabilizer bar |
Rear: | Independent, trapezoidal lower control arms, coil spring/shock absorber (gas charged) struts, stabilizer bar. |
Brakes | |
Service brake: | Anti-lock Brake System (ABS), hydraulic servo assist, dual braking circuits, load and lateral acceleration sensitive brake pressure proportioning |
Front, size and type: | 10.9 in, ventilated disc |
Rear, size and type: | 10.6 in, ventilated disc |
Wheels & Tires | |
Wheel size: | 8j x 16 forged light alloy (7.5j x 15 light alloy optional) |
Tire size: | 225/50 16 performance radial (215/60 15 all-season optional) |
Body | |
Material: | Fully galvanized (both sides) steel |
Corrosion protection: | multi-step anti-corrosion process |
Capacities | |
Engine Oil: | 5.0 U.S. quarts |
Fuel Tank: | 21.1 U.S. gallons |
Cooling System: | 9.0 liters |
Exterior Dimensions | |
Wheelbase: | 106.0 in. |
Front Track: | 61.5 in. |
Rear Track: | 60.1 in. |
Overall length: | 192.6 in. |
Overall Width: | 71.0 in. |
Height (unloaded): | 56.5 in. |
Ground Clearance: | 4.0 in. |
Curb Weight: | 3839 lbs. |
Interior Dimensions | |
Seating Capacity: | 5 |
Front Legroom: | n/a |
Rear Legroom: | n/a |
Interior Volume: | 94.1 cu. ft. |
Luggage capacity: | 16.4 cu. ft. |
Performance | |
0-50 mph (0-80 kmh): | n/a |
0-60 mph (0-100 kmh): | 6.2 sec. |
1/4 Mile: | 14.9 sec. |
Top estimated speed: | 130 mph (electronically limited) |
Fuel Economy | |
City: | 18 mpg |
Highway: | 23 mpg |
Combined: | n/a |
Standard Features | |
Comfort/Convenience: | • Automatic climate control system • Power glass sunroof (tilt and slide) with automatic preselect • Power windows with driver one-touch down and convenience close features; lock-out for rear windows and cigarette lighter • Tilt and telescopic steering wheel • Tinted glass, banded windshield • Electronic cruise control with resume • Dual power mirrors with memory, defog, tilt revers (right–hand side only) • Electric rear window defogger • Power central locking system including trunk and fuel door with windows/sunroof close feature • infrared remote activation of locking system, alarm, seat and mirror memory • Power trunk release • Thigh adjustment for front seats • Heatable front and rear seats • Heat ducts to rear seat area • Cellular telephone (hands-free/voice recognition) • Illuminated glove box, trunk, lighter/ashtrays, engine compartment • Ignition key with infrared transmitter • Dual illuminated vanity mirrors • 4-passenger assist handles with 3 reading lights • Cupholders (in center console) • Time delay interior light • Expandable ski-storage sack • Anti-theft vehicle alarm system • Fuel cap hanger • Day/night rearview mirror |
Interior/Seating and trim: | • 8-way power front seats with manual lumbar adjustment and memory functions for driver seat and outside mirrors • Leather seat upholstery • Front seatback map pockets • Leather-wrapped steering wheel • Leather shift knob • Open head restraints, front and rear • Folding front-center armrest with cellular phone • Long center console with rear air vent • Fold-down rear center armrest • Carbon fiber inlays for dash and door panels |
Instrumentation: | • Backlit instrument cluster with additional gauges (oil temperature, oil pressure, coolant temperature) • Light grey instrument faces • Tachometer and electric speedometer (160 mph) • Trip odometer • Active Auto check System • Outside temperature gauge (separate) • Analog clock • Intermittent wiper mode |
Audio Systems: | • Audi/Bose music system with anti-theft AM/FM stereo cassette radio and 4 acoustically tuned speaker modules • Dual diversity antenna system |
Exterior: | • Aerodynamic halogen headlamps with integrated fog lights (ellipsoid beams for low beams and fog lights) • Headlamp washers, retractable • Integrated, body colored front and rear bumper aprons • Protective side moldings • Heatable windshield washer nozzles • Intensive windshield washer system • Body color flush door handles • Body color outside mirrors • 5 mph bumpers • Chrome exhaust pipe tips • Convex, right outside mirror • Front fog lights • Rear fog light • Clearcoat metallic paint |
Safety: | • Child-safety rear door locks • 3-point front seat belts with height adjustment • Driver and front passenger air bag supplemental restraints • Automatic self-tensioning front seat belt system • Rear outboard 3-point seat belts • Safety reflectors on all doors |
