April 4, 2013
Source: AWE Tuning
Willow Grove, PA – AWE Tuning is excited to announce the AWE Tuning 2.0T Boost Tap for B8.5 Audi 2.0Ts.
The tap itself is constructed of lightweight, incredibly strong CNC Machined Aluminum, which is anodized black for long life, and laser etched with the AWE Tuning logo. The tap incorporates two injection molded ports for added flexibility. The Boost Tap was designed with a double o-ring seal for leak free operation.
Included in the kit is all of the hardware youll need for installation, as well as a specifically chosen 3 hose extension, constructed of reinforced silicone for strength, heat resistance and durability.
The 2.0T TFSI Motor used in the 2013+ A4 and A5 requires a unique boost tap due to a change in layout from the pre-facelift B8s. Enter the AWE Tuning 2.0T B8.5 Boost Tap. Its simple, elegant, easy to install and reliable not to mention an incredibly economical way to tap into this generation of 2.0T TFSI Motor for both boost and vacuum, states AWE Tuning VP of Marketing Jesse Kramer.
The set up re-uses the original equipment fittings, making this a simple installation, while retaining factory reliability.
The AWE Tuning 2.0T Boost Tap design allows for integration with any aftermarket Boost Gauge or Diverter Valve.
![AWE Tuning releases Boost Tap for 2013+ Audi 2.0T](https://www.audiworld.com/wp-content/uploads/2013/04/header6.jpg)
AWE Tuning B8.5 2.0T Boost Tap highlights:
Boost source for Boost Gauges on 2013+ Audi A4 and A5 2.0T engines
Includes everything needed to install
Allows simple integration of AWE Tuning boost gauges or other upgrades that require tapping the line
Two injection molded plastic ports for added flexibility in application
Machined, sturdy engineering
Simple Installation
More information, performance specifications and pricing can be found on AWE Tunings website in the AWE Tuning B8.5 2.0T Boost Tap section, or by calling AWE Tuning directly, at 888.565.2257. The Boost Tap will be sold online in the AWE Tuning B8.5 2.0T Boost Tap section or through one of AWE Tunings global network of choice retailers around the globe.
