Faster than an SQ5 TDI plus – the new ABT Super-Q5 has 365 HP
ABT_SQ5_006-01
ABT Sportsline makes the Audi SQ5 even faster than it is: With 365 HP/ 268 kW and an optimised torque of 710 Nm, the Bavarians have topped the SQ5 TDI competition’s original 326 HP/ 240 kW. This new power is primarily reflected in these measurements: “From naught to 100 kph in less than 5 seconds and a new top speed of 260 kph.” And CEO Hans-Jürgen Abt adds: “But that is not all. We also provide quality, which finds expression in our extensive warranty and the most thorough tests, on both the dynamometer and on public roads.“
ABT_SQ5_010-01
The powerful ABT Sportsline car’s “body language” says it all. The Aero package includes the front skirt and a new grill, door strip attachments and a rear wing. If you choose the wide version, you will also get the right fender extensions. As bodywork material, PU is used almost exclusively, which, incidentally, is also the OEM’s material of choice. Various wheel spacers of between 30 to 70mm per axle make for the right tread and an even more assertive presence – especially if ABT height adjustable suspension springs are used as well. These allow for a variable lowering of between 5 and 30mm on the front axle and of between 10 and 35 on the rear.
ABT_SQ5_009-01
For this set-up, the ABT Sportsline wheels in 20 and 21’’ are perfect. You can choose between the CR, DR, ER-C and FR, some of which are even available in different colours.
ABT_SQ5_008-01
The new ABT Audi SQ5 – data and facts
ABT ENGINE TECHNOLOGY
Engine:                                                 3.0 TDI, 2.995 cc capacity
Performance tuning:                              ABT POWER “New Generation”
Performance:                                        365 HP/ 268 kW (standard: 326 HP/ 240 kW)
Torque:                                                 710 Nm (standard: 650 Nm)
Performance:                                        360 HP/ 265 kW (standard: 313 HP/230 kW)
ABT AERODYNAMICS
ABT front grille
ABT front skirt
ABT fender extensions
ABT door strip attachments
ABT rear wing
ABT WHEELS IN DESIGNS CR, DR, ER-C and FR in 9.0 x 20 inches, 9.5 x 20 inches,
9.0 x 21 inches and 10.0 x 22 inches
Available also as complete set of wheels with Continental or Pirelli sports tires in 255/45 R20,
255/40 R21, 255/35 R21 and 265/35 R22
ABT SUSPENSION
ABT wheel spacers (30, 50 and 70 mm)
ABT height adjustable suspension springs (FA ca. 5-30 mm; RA ca. 10-35 mm)
ABT INTERIOR
ABT floor mats
ABT trunk mat
