1993 Audi S4
[insert_php] if ( function_exists(‘yoast_breadcrumb’) ) {yoast_breadcrumb(‘ ‘,’ ‘); } [/insert_php]
93-s4
1993 Audi S4
Colors and Available Options
Available Options:
  • 10-disc CD changer
  • Pearl White metallic paint
  • Delete sunroof
Available Exterior Colors: n/a
Technical Specs
Engine/Engine Design
Type: 2.2 liter, 20 valve, turbo-charged, 5-cylinder, in-line, electronic turbo-boost control.
Bore: 3.19 in.
Stroke: 3.40 in.
Displacement: 136 cu. in.
Compression Ratio: 9.3:1
Horsepower (SAE Net): 227 @ 5900 rpm
Torque: 258 @ 1950 rpm
Cylinder block: Cast Iron
Crankshaft: n/a
Cylinder head: Aluminum alloy
Valve Train: Belt driven, hydraulic lifters
Firing Order: 1-2-4-5-3
Cooling System: Water-cooled, thermostatically controlled electric fan
Fuel/Ignition System: Bosch Motronic electronic fully adaptive sequential fuel injection/ignition system, hot-wire air mass sensor, fault memory, dual knock sensors,
Drivetrain
Type: Quattro all-wheel drive
Transmission: 5-speed manual transmission
Gear Ratios:
1st
2nd
3rd
4th
5th
Reverse
Final Drive
Manual
3.50:1
1.89:1
1.23:1
0.99:1
0.73:1
4.11:1
n/a
Steering
Type: Rack & pinion, power assisted
Ratio: n/a
Turns (lock-to-lock): n/a
Turning circle (curb-to-curb): n/a
Suspension
Front: Coil spring/shock absorber (gas charged) struts, lower control arms, stabilizer bar
Rear: Independent, trapezoidal lower control arms, coil spring/shock absorber (gas charged) struts, stabilizer bar.
Brakes
Service brake: Anti-lock Brake System (ABS), hydraulic servo assist, dual braking circuits, load and lateral acceleration sensitive brake pressure proportioning
Front, size and type: 10.9 in, ventilated disc
Rear, size and type: 10.6 in, ventilated disc
Wheels & Tires
Wheel size: 8j x 16 forged light alloy (7.5j x 15 light alloy optional)
Tire size: 225/50 16 performance radial (215/60 15 all-season optional)
Body
Material: Fully galvanized (both sides) steel
Corrosion protection: multi-step anti-corrosion process
Capacities
Engine Oil: 5.0 U.S. quarts
Fuel Tank: 21.1 U.S. gallons
Cooling System: 9.0 liters
Exterior Dimensions
Wheelbase: 106.0 in.
Front Track: 61.5 in.
Rear Track: 60.1 in.
Overall length: 192.6 in.
Overall Width: 71.0 in.
Height (unloaded): 56.5 in.
Ground Clearance: 4.0 in.
Curb Weight: 3839 lbs.
Interior Dimensions
Seating Capacity: 5
Front Legroom: n/a
Rear Legroom: n/a
Interior Volume: 94.1 cu. ft.
Luggage capacity: 16.4 cu. ft.
Performance
0-50 mph (0-80 kmh): n/a
0-60 mph (0-100 kmh): 6.2 sec.
1/4 Mile: 14.9 sec.
Top estimated speed: 130 mph (electronically limited)
Fuel Economy
City: 18 mpg
Highway: 23 mpg
Combined: n/a
Standard Features
Comfort/Convenience: • Automatic climate control system
• Power glass sunroof (tilt and slide) with automatic preselect
• Power windows with driver one-touch down and convenience close features; lock-out for rear windows and cigarette lighter
• Tilt and telescopic steering wheel
• Tinted glass, banded windshield
• Electronic cruise control with resume
• Dual power mirrors with memory, defog, tilt revers (right–hand side only)
• Electric rear window defogger
• Power central locking system including trunk and fuel door with windows/sunroof close feature
• infrared remote activation of locking system, alarm, seat and mirror memory
• Power trunk release
• Thigh adjustment for front seats
• Heatable front and rear seats
• Heat ducts to rear seat area
• Cellular telephone (hands-free/voice recognition)
• Illuminated glove box, trunk, lighter/ashtrays, engine compartment
• Ignition key with infrared transmitter
• Dual illuminated vanity mirrors
• 4-passenger assist handles with 3 reading lights
• Cupholders (in center console)
• Time delay interior light
• Expandable ski-storage sack
• Anti-theft vehicle alarm system
• Fuel cap hanger
• Day/night rearview mirror
Interior/Seating and trim: • 8-way power front seats with manual lumbar adjustment and memory functions for driver seat and outside mirrors
• Leather seat upholstery
• Front seatback map pockets
• Leather-wrapped steering wheel
• Leather shift knob
• Open head restraints, front and rear
• Folding front-center armrest with cellular phone
• Long center console with rear air vent
• Fold-down rear center armrest
• Carbon fiber inlays for dash and door panels
Instrumentation: • Backlit instrument cluster with additional gauges (oil temperature, oil pressure, coolant temperature)
• Light grey instrument faces
• Tachometer and electric speedometer (160 mph)
• Trip odometer
• Active Auto check System
• Outside temperature gauge (separate)
• Analog clock
• Intermittent wiper mode
Audio Systems: • Audi/Bose music system with anti-theft AM/FM stereo cassette radio and 4 acoustically tuned speaker modules
• Dual diversity antenna system
Exterior: • Aerodynamic halogen headlamps with integrated fog lights (ellipsoid beams for low beams and fog lights)
• Headlamp washers, retractable
• Integrated, body colored front and rear bumper aprons
• Protective side moldings
• Heatable windshield washer nozzles
• Intensive windshield washer system
• Body color flush door handles
• Body color outside mirrors
• 5 mph bumpers
• Chrome exhaust pipe tips
• Convex, right outside mirror
• Front fog lights
• Rear fog light
• Clearcoat metallic paint
Safety: • Child-safety rear door locks
• 3-point front seat belts with height adjustment
• Driver and front passenger air bag supplemental restraints
• Automatic self-tensioning front seat belt system
• Rear outboard 3-point seat belts
• Safety reflectors on all doors
