1.8t audi a6 99 AEB oil warning
I’ve some problem with oil warning. When engine is hot some like 90C and I’ve accelerate more than 3000RPM FIS shows me Oil warning then when pushed left button to check what is going on the message is: “switch off engine, check oil level”
It happens often and always when engine is hot.
Untill now I have check ed:
Oil pressure in 2 way on hot and on cool engine and the result was:
IDE 1.6 BAR
2500 RPM between 3.2 – 3.4 BAR
5000 RPM 4.6-5.3bar
replaced head gasket and completed rebuilding the head .
compression result :
11.6 11.8 12.0 11.8
Replaced pressure sensor cause I have observed that during pressure measure when I plug off the sensor, on dashboard I have the same warning “switch off engine, check oil level”
So you may be guess how was my surprise, I thought that will be some like “ stop check oil pressure” I think the all sensor temp. , press. and oil level are connected with one warning.
And still have the same problem “switch off engine, check oil level”
Today I’ll change temperature sensor, and I should mention that I didn’t find oil level sensor,
I search that sensor on sump but with miserable effects.
What’s now ?
IDE 1.6 BAR
5000 RPM 4.6-5.3bar
11.6 11.8 12.0 11.8
What’s now ?
dangelo
A4 (B8 Platform) Discussion
08-26-2023 09:47 AM
JsprZ
13
10-29-2006 06:42 PM
Luxus Panzer
9
09-29-2004 06:41 PM
