1.8t Engine Noise after shutdown
2002 1.8t Beetle.
After shutting down the engine, I hear a small vibrating noise close to alternator and compressor.
It goes for like 8 minutes...
Is this normal..?
It sounds like a vacuum pump.
May be connected to the EVAP System.
Thanks.
m015073
Is this normal..?
Thanks.
m015073
Re: Not normal. The turbo spins down for several minutes after the engine stops.
Thanks for the reply!
This sound appears to be coming from the front part of the engine close to the radiator. The pipe that this black vibrating box is connected to is also connected to a radiator hose.
The circular box is mounted to the Radiator Housing. I checked another Turbo Beetle, and it was also making this noise. Not sure if this is normal since the referenced Beetle I am not sure of the maintenance or how it runs.
Any ideas..?
Any ideas..?
Re: Coolant afterpump?
This starts making more sense now.. I was not sure of these cards had something like this. I'll start investigating about this.
Thanks!
m015073
Thanks!
m015073
NiceS4
11-19-2007 08:57 PM
BrianG
03-20-2006 12:57 PM
freeman
08-12-2001 07:41 PM
