2002. 1.8T A4 Replace Head Gasket???
So while doing some little trouble shooting, car has a little hesitation low gears around 2-3k rpm, so I went for the spark plugs because the coils were replaced recently, fixed my problem, but noticed that there is a little oil leaking around the valve cover gasket, to the point I found a little in the #4 coil pack, now, to the question, how difficult is it for DIY project?? The only mechanical experience I have is just that, replacing coil packs and spark plugs????
I doubt it's the head gasket that's leaking, but you might want to think about doing the valve cover gasket and spark plug well o-rings that come with a VC gasket kit.
http://www.blauparts.com/proddetail....21005&cat=4277
This is what a link to a quick google search.
http://www.audiforums.com/forum/showthread.php?t=8418
There is lots of info on the forums and it would help you if you had Bentley manual.
FYI be real careful and if you are not comfortable approaching this job, than don't.
Cmmartin23
26
08-23-2016 04:44 PM
Audi Other S6 2002 FS
dorschman
09-17-2015 03:24 PM
Jorge Vargas
09-08-2015 07:45 AM
