Anyone using Mobile Tuner to increase boost?
Old 11-10-2004, 01:51 PM
Member
jprice@CPS's Avatar
Old 11-10-2004, 08:02 PM
Member
[ej257]'s Avatar
Default Still running a k03?
I can't imagine that the k03 has anything left to give.
Mobile tuner is so new, you might be the first.
Old 11-10-2004, 09:00 PM
Member
Devious27t's Avatar
most people just use lemmiwinks as most of the chips arent MT enabled any DBW can use lemmiwinks
Old 11-10-2004, 10:32 PM
Member
jprice@CPS's Avatar
I have an MT enabled chip..
Old 11-10-2004, 10:34 PM
Member
jprice@CPS's Avatar
Default Yeah, still on K03.. there is a little more that can be squeezed out..
My n75 is only getting up to 75%.. with MBC only, car was quite a bit faster, just not as driveable. I'm trying to find a way to get the driveability and the boost. However, even with the MT enabled chip, for some reason I can't get it to request or get actual above 1.1 bar. Even though it accepts the values from MT, it doesn't change boost after a value around 180 (goes to 255).
Was hoping someone else had better luck or knows something I could try :-(
Old 11-10-2004, 11:04 PM
Member
Devious27t's Avatar
Default your duty cycle on the N75 is 75% @ 1.1 bar?
and for clarification the car will only request up to 1.1 bar at which point the actual will match that? if these numbers arent lining up you might have a WG problem which is why i was asking for clarification.
maybe its b/c of your VW universal MAF... haha i keed i keed.
Old 11-11-2004, 12:48 AM
Member
jprice@CPS's Avatar
LOL!! Stock MAF.. stock everything.. except chip. :-)
Old 11-11-2004, 12:49 AM
Member
jprice@CPS's Avatar
Default Yeah.. I'm getting what is requested..
Point being that it could do more :-)
Old 11-11-2004, 09:17 AM
Member
Devious27t's Avatar
Default that could be the maximum parameter within which you can tune garrett is pretty conservative when it
comes to that he doesnt want people blowing up their motors so he doesnt really give me freedom to it. what troubles me is that you are only getting 1.1 bar out of an Xchip do you have a boost gauge and if so is it reading the same? i was under the impression that chip was running like 1.4 bar?
Old 11-11-2004, 12:36 PM
Member
jprice@CPS's Avatar
Default Depends on weather conditions...
it's 50 degrees here now and I'm holding 15-16 PSI. No leaks in the system, and I am getting what is requested. I am not hitting a max parameter, something else is going on, just trying to find out what it is :-D
Quick Reply: Anyone using Mobile Tuner to increase boost?
