Anyone using Mobile Tuner to increase boost?
#21
It's supposed to allow up to 25% MORE boost than the regular GIAC K03 programs. Directly stated, in a file that came with the program.
I was simply trying to find out if anyone has had success in adjusting the boost UP with the programming, regardless of the turbo.
#22
and in what conditions? 100 degrees? Right now in 40s-50s, my X is only requesting 1900mbar absolute max, and I'm getting about 1.1 bar. I have assumed that it's simply the colder weather.. less boost is required.
#23
allow the value to be raised above that 1.4 bar. So if you have a "1.1 bar chip" yes you can push it further up with the MT but the X-chip is tuned to run 1.4 bar of boost already.
#24
in 70+ deg temps. Once you fall below that the boost will also decrease beacause of a few factors which are more dense air at lower boost levels and the fact that the engine is producting higher vacuum.
bballfreak
9
04-14-2019 06:59 PM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
ECS Tuning-Audi
02-04-2016 08:36 AM
