Coilpack/Spark Plug/Injector issue possible...
I replaced all the plugs on my car and it is still sputtering at low RPM in second gear...
How can I tell if it is the coilpacks that are bad, or possible a bad injector? More specifically how can I tell which one it is using the Vag if my car isn't throwing a CEL?
Actually posted about the problem when my car started running rough at times but it always cleared up. The check engine light was on so I took it to have it checked. The code was showing a misfire on the #2 cylinder. To be honest I was not sure how the cylinders were numbered so I switched the inners with the outters and had the check engine light reset. I took it out on the road and waited for it to spit and sputter again and checked the code once more. The misfire moved to cylinder #1. I think your check engine light would come on but I am a confessed rookie with Audi. However the first little sputter during this time my light came on instantly even if it cleared right up.
