FML timing belt problem PLEASE HELP!!
Change timing belt and accessory belt put the damn car back together and now i have to codes and car runs funny. At first it stared right up then when i went to move it out the garage it took a lil bit to start. After it started i noticed the check engine light was on so i scanned for codes and got two, 16725 and 41110. I know what the 16725 code is but the 41110 code I imagine is what is trying to F^#% me in the ***. If any on has any insight on the PLEASE HELP, my classes start back up tomorrow. Thanks!
yea, at first i only got th 16725 code. I had not unplugged the cps so i didn't understand that code. I went back checked the connection then i cleared and started it again the code cam back with the other 41110 code. Doesnt make sense to me either.
what are you using to extract your codes? Are you using VCDS or a generic OBDII Scanner? You wouldn't happen to be in CT or NYC, would you?
Im in florida, I used a generic reader to upll the codes. I didn't drive it ANYWHERE. I tore the car back down and re-did everything and the timing was off. Just reset it put it back together, cleared the codes and they haven't come back so it looks like its all good. Been driving it a week now with no troubles. Only abnormal thing is its running really cool, I guess I put too much coolant in. No complaints here. Thanks for the help all!
