Hope this is a really quick question
I pulled my MAF out to clean it (due to a lean run, bank 1...something like that).
While looking over the MAF sensor. It looks as if there is a "pict-o-gram" of resistor on the side of the sensor. There is also locations where the resistor could be pressed into.
So, question I have is. Is there supposed to be any resistors on the side of the sensor?
Thank you very much for your time,
Sean
Sean
Re: Ok for sure then no.
hummm ok...cool. It was looking odd. I was thinking that it would kinda suck to have electronic parts whizzing through a turbo then shot into an engine and then yeah...that all would suck.
I am now thinking the lean code "P0171" bank 1 may have something to do with the wide range O2 sensor. I have found torn vacuum hoses and replaced them. Disconnected the battery for some time to turn off the MIL. Then let the car adapt.
Today I also added seafoamed to the crankcase and gas tank. I figure I have had this car for two weeks. I have replaced the clutch, vac hoses, and battled with the heater core numerous times. I finally won that war. Heater is now working great.
Scratch, want to thank you for your help. Your post helped me get to the bottom of the problem.
Sean
Sean
GinCQ
14
07-11-2008 09:29 AM
Torsen1
10-14-2003 08:31 AM
