Loss of coolant
Hi guys, had a look around but everyones problems seem to differ around this subject. I'm having the problem of losing a lot of coolant every day, though cannot see any leaks. I'm topping it up with water if thats an issue? And it requires topping up every morning. I've checked the engine oil cap to see if theres any sludge on it and there isn't any. Not sure if it is the head gasket. It drives for about 10/15mins until the low coolant level or overheat starts going off. Can see any signs of a leak, would be great if somebody got point me in some sort of directions.Thanks!
Could be cracked cylinder and getting burnt up in combustion chamber like mine was doing just replaced my head but its still idling so sooo rough and Im stuck!!! Are you getting any air built up in the coolant reservoir and do you have heat?
LordKarnage17
10
01-10-2018 05:30 PM
I seem to be slowly losing coolant, and I notice a burning smell after driving...smells like coolant
nvr_follow
23
02-21-2008 06:12 PM
GTA_Driver
06-13-2007 07:38 PM
