Odd chirping noise
Old 07-08-2006, 08:43 PM
  #11
diagnosticator1's Avatar
Default It's a DIY, here's how:
Find the DV located below the passenger headlight, between the turbo outlet hose and the radiator end tank. Follow the small vacuum hose that is connected to the top of the DV, up to the other end of that vac hose, at it's connection to the (or Intake manifold) N279 solenoid valve under the intake manifold. Now, backup down the hose toward the DV, and where the hose is easy to get to near the front end of the manifold, cut the hose. Now, connect a vacuum hand pump and pull a vacuum on the DV diaphragm. You must be able to pull a vacuum of at least 20 in Hg, that does not leak away after achieving that value, without further pumping, for a minimum of several minutes. It there is leakage make sure your connections and the pump release valve are not leaking. If the diaphragm has a hole or is torn, you will not be able to pull a vacuum or it will leak off almost as fast as you can pump. After testing, use a 1/8" double hose barb to reconnect the hose at the cut point.
Old 07-08-2006, 09:35 PM
  #12
Member
Yippers®'s Avatar
Default He has a 99 no need to cut the hose he can just pull it off the nipple on the manifold. But, I doubt
a torn valve diaphram would 'chirp' for only the first couple of minutes after a start. Since he described it as only ocurring when the car was either cold or allowed to sit (cool a bit) from fully warmed I would suspect something that is temperature dependant ...
Old 07-09-2006, 01:29 AM
  #13
Default Thanks for that clarification, that simplifies the DV test, easier for sure. ....
It's true the descriiption of the noise suggests a temperature dependency, but the DV is suspect until ruled out. It is one step in a process of illimination.
Old 07-17-2006, 10:31 AM
  #14
New Member
bieny's Avatar
Default Mine does the same
my car (1.8t 1998) is doing exactly the same thing! started a few weeks ago, i thought it was the chain tensioner but its still the same after i put a new one on. Also did all the belts at the same time. but i cant find the noise, also im sure i can hear the turbo louder than before?
montanamana
39
10-05-2022 09:31 AM
bieny
1.8T Discussion
07-30-2007 11:40 PM
guido79
11-05-2004 02:08 PM
setUout
01-20-2004 11:28 AM
freeman
08-12-2001 07:41 PM
Quick Reply: Odd chirping noise
