Rough idle and no power
I have an 04 A4 1.8T-92,000Miles Suddenly Engine Light came on and starting running rough with Engine light flashing sometimes. Just got it home. afraid to move it.
When i first got the car, it idled very rough and the check engine light came on. Took it to an Autozone and multiple fault tests were received. I replaced the plugs, mass air flow and one air hose/valve which had a leak near the back of the engine. This fixed the rough idle problem and i got Autozone to clear the codes but the Engine light came back on. Now there is only 1 fault code, P0171. I've seen some forums saying to check for any leak or possibly the O2 sensors?
That code is for:Fuel Trim; Bank 1: System Too Lean
Possible Causes
Mass Air Flow Sensor (G70) defective
Possible Solutions
Check Mass Air Flow Sensor (G70)
Check Fuel Pressure Regulation
Check Fuel Pump
Check Injectors
Check Intake System for Leaks
Check Exhaust System for Leaks
Check Secondary Air System for Leaks
Check Vacuum Pipes for Leaks
Possible Causes
Possible Solutions
Check Fuel Pump
Check Injectors
Most first guesses are the 02 sensor... Mine turned out to be either a dirty MAF sensor, or a loose vacuum hose. I cleaned the MAF really well with sensor clean, and tightened up a vacuum hose (seemed tight in the first place) and it was finally fixed after about a year of fiddling with things.
Before that I'd changed a cracked vacuum hose, replaced the fuel filter, and spark plugs, and changed the front position o2 sensor in an attempt to get rid of the all too familiar p0171 code.
Oh, and also, I remember reading something about a gate in the airbox that can get stuck open and cause the car to go into "limp mode" from what I can recall... may explain your loss of power etc.?
Flashing light means something wrong with your catalytic converter - could cause limp mode I'd imagine.
Someone with VAG-Com can probably narrow it down to something alot more specific.
Another poster was having ignition issues and this turned out to be the problem... easy to do, so would be worth a look.
Check plugs for fouling - that can also tell you alot.
KiddJoey
06-01-2001 01:39 PM
