are these codes for the FRONT 02 sensor?
Address 01: Engine
Part No: 8E0 909 518 AF
Component: 1.8L R4/5VT G 0003
Coding: 0016711
Shop #: WSC 79670
2 Faults Found:
16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 001 - Upper Limit Exceeded
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
P1103 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0001
Coding: 0016711
Shop #: WSC 79670
2 Faults Found:
thanks. if that is the only code being thrown on my car do you think when replaced i should be able to pass inspection even though i have a test pipe and no cat. i am from ny
I'd bet as soon as you replace sensor 1, you'll start to get codes and a check engine light related to either the cat or sensor 2. The car will know the cat is not working properly (or not there) because it compares the values from the 2 sensors to see if the cat is working properly, it will see little or no change and set a code. I probably skips this if sensor 1 is bad.
When they check your emissions I doubt it would pass with out the cat. Also, they may fail you if they happpen to notice that the cat is missing. I used to work in a shop and did NY inspections, and we would never have missed a non-existant cat.
You can always take a chance and see what happens, maybe you'll get lucky. All you really have to lose is the cost of the inspection.
thanks for all your help man. i ended up doing some shady **** to get my car inspected but you were right on with all your info. thanks again
mmart6545
01-26-2004 05:09 AM
mrsteve
05-15-2003 08:04 PM
