unplugged n75 and no difference when I drive it. I also hear a slight leak coming from that
Did you ever reset the ecu by unplugging it? It may be in limp mode... do you have a boost guage?
They become really nice at finding boost/vac leaks... should hold ~20 hg.
I unplugged Bat then plugged it back on after 30 min I had the check engine light on for about 10 sec then went away. it gets worse as it gets warmer. I'm going to grab a VAG tomorrow we need to see exactly whats going on. I really think it's my N75. makes absolutely no difference when I unplug it.
Once again thanks for all your help
OK I ran a Vag test and came back with
1. P0113-Intake air temp sensor 1 circuit high input
2. P0243-Turbo charger wastegate selenoid
3. P0304-Cylinder 4 Misfire
4. P0303-Cylinder 3 Misfire
5. P0333-Knock sensor 2 circuit high input
6. P0300-Random Misfire
Cleared all the codes
#1 came back straight away
#2 Came back After I started it
and #3 Came back when the car warmed and started coughing and spluttering
end result
DTC Information
Pending Codes
P0243 Turbocharger Boost Bypass Solenoid (A) Circuit Open/Short Circuit
Conditions For Setting This Code:
Possible Causes:
Monitor Information:
P0304 Cylinder Number 4 Misfire Detected
Possible Causes:
P0113 Intake Air Temperature Sensor Circuit High Input
Thanks again I hope this help I think that my coil is gone on number 4, I have tried the unplug test and did not notice a difference
end result
DTC Information
Pending Codes
Possible Causes:
Possible Causes:
Completely lost I looked at my intake sensor, which I think is located next to and under my throttle body.. what else would I look at? How do I test it and there is 2 wires there Brown and green which one goes where they both fit in exactly the same plug?
Thanks again I am almost there will pickup a new set of coils on Monday.
That P0113 error comes on as soon as the ignition is turned on
Email Joe@axismotorsport.com
He can get you the best deals on Coilpacks and the like. His website doesn't have everything, buthe can get anything.<ul><li><a href="http://www.axismotorsport.com">http://www.axismotorsport.com</a></li></ul>
