What are the cons of "knocking the guts out" of the catalytic converter
I had my 1.8t rebuilt and as I am putting everything back together, I am thinking about knocking the guts out of the converter. I am curious if it will have any adverse effects on the engine, more specifically the O2 sensors.
depending on the engine (AEB, ATW, etc) you may or may not get a CEL from the rear O2 sensor. You will have to use nonfoulers on the rear sensor.
The front sensor monitors the A/F ratio, the rear sensor does cat efficiency.
Gutting the cat or using a test pipe will not harm the engine.
non fouler are extensions for the sensors that will move it out of the airstream. The AEB works well with non foulers.
The B5A4 forum has a great FAQ that will answer nearly all of your questions.
We really don't bite over there, just expect noobs to STFA (search the fvcking archives) before asking a question that has been answered several hundred times before.
A4orce84
03-10-2008 12:55 PM
