"Oil" In Trip Meter Wtf?
IN my trip meter it keeps saying oil and i check it out and the Motor Oil is good..... dont they have another sign that says to check motor oil on A 1997 Audi a4 2.8?
well anyways it was correct yesterday the oil was short i filled it to the good point and drove it around and the "oil" Word went away.
this morning i turn the car and it says Oil i was like damn it and im here now with this to share to you guys. you think Motor Oil might be leaking?? or is the damn car Hungry for oil in cold weathers.
And the Gauge thing still happens it will turn off itself when the car is on and it would reset the trip metere to 0 miles but the speedmeter is still the same. this is wierd it cant be the battery or the car wouldnt start am i right? it might be something maybe inside of the Gauge cluster?? bad connection and the cold weather brought it up? well anyways any help will be great!!! thanx Guys
Edit : "Oil" in trip meter i found how to remove it for 98+ 2.8s but it dindt work in my 1997
anyone have a clue how to get rid of it?? people says its just a reminder to check oil if u havent already it does it like every 7k miles well anyone ever experineced with this??
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
You need a VAG tool to reset it. If you're in MD, I don't mind resetting it for you. You may also see in1 or in2 there for Inspection Service 1 or 2. Same thing, just an interval and needs to be reset with VAG. You can temporarily make it go away by holding in the trip button but it will come back next time you start the car. It does stop after a few minutes.
or is it a 5 second thing and be alot cheaper? or can i just disconnect my battery? and it will reset everything will that do the trick and do u know the other reason why my gauge resets itself in the morning??
& reset it yourself. My dealer charges $75 to do it each time. See link below.<ul><li><a href="http://www.obdtool.com/">http://www.obdtool.com/</a</li></ul>
least not the same amount of software as ross-tech delivers. I think it's minimal software, ie; enough to allow you to diagnose/clear codes. Ross-Tech is good stuff and does come with software but I believe it's closer to $199.
It does just do small jobs such as clear codes, but it can be upgraded to the full version for $99. I only use mine for clearing codes & diagnostics, so I just have the basic program. Sorry for the confusion, I just woke up.
Talk about sodomy without the benefit of lubrication! It takes less than 5 minutes.
And, NO, that is not the RossTech vag tool. But it does work with the RossTech software. To reset the interval you'll need to buy RossTech's cable and software registration which is $199 for the unicom cable. Or you can buy the $70 cable from the site you listed and pay $100 for the RossTech software registration.<ul><li><a href="http://www.ross-tech.com">RossTech's website</a></li></ul>
Yes, my dealer charges 1 hr labor (hence the $75) just to do that. That's why I bought my own tool.
