4 wire to 3 wire MAF swap successful. Updated.
#11
I think in the long run I'd like to actually own the program (Freeware or Full version -if there is such a thing-) instead of borrowing units, because I've read how useful its functionality has been to other members.
& thanks for confirming the ECU tap. check yah later
#14
to get the individual pins out of the connectors.
There's a small metal tang, which holds them inplace. You use the small driver, to press down on the tang, while pulling back on the wire. ;O)
#18
<center><img src="http://pictureposter.audiworld.com/70334/ecuharness.jpg"></center><p>
MAF/CO pot pin 4 corresponds to ECU connector "A" pin 1. It's the only ECU connector with 12 pins.
