93 90CS still misfires....
Old 10-22-2008, 07:44 PM
  #11
CRAZY_RUSSIAN's Avatar
Default were you able to clean it?
if so, how? or did you just replace it?
Old 10-22-2008, 11:53 PM
  #12
Default result...
here are the readings that i got from the coil
3-5=12.86
2-4=12.05
1-6=11.84
good?bed?fugly?
its almost 2am and i'm going to sleep...
what the hell is wrong with this stupid caR?!
p.s. just remembered something, i do not have a vacuum tank, i have the line caped off. dose that make a huge difference?
Old 10-23-2008, 08:26 AM
  #13
Default post just disapered....
ok, there were like 3 posts here that just vanished... wtf?
tested resistance in the coil
3-5=12.86
2-4=12.05
1-6=11.84
good? bed? ugly?
p.s. i just remembered something, i'm lacking a vacuum tank and i have that line caped off, will that make a difference?
Old 10-23-2008, 08:52 AM
  #14
VAP
VAP's Avatar
Default rather than edit his post the person that recommended testing by water deleted his post...
that in turn simultaneously deletes ALL responses to his post. That of course deleted the Bentley procedure for testing coils and primary resistance I posted for you.
Basically you're good coil-wise as the Bentley spec is that each coil must register resistance between 9 and 14k Ohms at each coil which you've now done.
The other test I mentioned in that post is one that moribundman mentioned below and has to do with the "primary resistance" between the coils and the POS (power output stage) and involves testing the 3-wire harness that runs from the POS to the coils. Those leads should show resistance between .5-1.0 Ohms. If out of range either way that 3-wire harness lead should be replaced or you risk a similar failure to what moribundman experienced below. Test is simple and only involves using a multimeter at opposite ends of terminal #1, 2 and 3 for resistance.
Old 10-23-2008, 10:42 AM
  #15
EDIGREG's Avatar
Default You can however dig up response posts by finding the post number...
Here is the procedure for future reference:<ul><li><a href="https://forums.audiworld.com/12v/msgs/73162.phtml">https://forums.audiworld.com/12v/msgs/73162.phtml</a</li></ul>
Old 10-23-2008, 11:59 AM
  #16
odelay12v's Avatar
Default what idiot suggested to test electrical components with water?
DOH!!!
Old 10-23-2008, 04:53 PM
  #17
CK NYoC's Avatar
Default Just sprayed it with brake cleaner, not the optimumal way to clean an injector but it got rid of
the misfire.
Old 10-23-2008, 10:18 PM
  #18
Default i might just have to give that a shot...
if all fails.
should the injector seals b replaced?
Old 10-23-2008, 10:28 PM
  #19
Default that still just sounds bed...
ok, i work for a VW dealer as a parts consultant. I HAVE NOT HEARD OF ANYONE <b>ever</b> spraying water on a coil.
Old 10-23-2008, 10:42 PM
  #20
Default hey VAP...
so here is what i got.
from upper to lower terminal...
4.02
0.66
0.72
my coil is on its way out the door???
also i was wondering if this coil would work?
http://www.034motorsport.com/product_info.php?cPath=26&amp;products_id=278
thank you for all you help!!! :-)<ul><li><a href="http://www.034motorsport.com/product_info.php?cPath=26&amp;products_id=278">htt p://www.034motorsport.com/product_info.php?cPath=26&amp;products_id=278</a</li></ul>
Quick Reply: 93 90CS still misfires....
