AAH into a AFC car, Swap heads?
I bought an AAH engine out of a '94 90 to replace a spent AFC in a '96 A4 with low/no oil pressure and lots of extra noises. I was planning swap out everything on the long block to make it fit (intake , exhaust, etc.). As I was looking on the 12v.org website at the differences between the engines I saw that the 2 engines have different heads and therefore valve timing. Do I need to swap out the heads to get the AAH to work with my ECU? Anything else I may have missed?
system is installed with the AAH engine so the ECU will work. There are also differneces in the engine sensors between the AAH and AFC engines that tie into the motor management system (MMS). Your '96 AFC engine has MMS 400 or 411, while the '94 AAH engine probably used MMS 300. You can make the switch, but you'll need to do some research to ensure the newer ECU communicates with the older AAH engine.
Hello....
I was wondering if any more information was dug up about the ECU - engine compatibility.
I've got a 96' A4 AFC engine in a 95' cab.
It keeps throwing EGR low flow codes and fuel rail trim stuff.
I've been through the EGR system pretty closely, but not finding the culprit.
thanks.....
thanks.....
carl viking
40
07-12-2024 02:45 PM
N'Syncro
33
02-16-2020 03:12 PM
