Blower thoughts.
<center><img src="http://pictureposter.audiworld.com/80531/lower_intake.jpg"></center><p>I was looking at this pic of the lower intake. I will def. have to cut out everything removed in the pic to fit in the Eaton upside down. I will cut what is left of the intake runner down even with the injector port. I think it will be way easier to cut, or grind this away so I can mate the intake runners with the round section of the stock runner just before it enters the head.(instead of forming something to the D shape top of the lower intake half.) Let me know what you think,
late,
keith
late,
keith
but it seems like it would be easier fab with the SC upside down and a intake man. overtop. Of course i'd put some heat shielding between it and the vallypan.
I was planning to make a IM with a larger volume and longer runners than what the PES system is using. They seem 'very' short to me. The only book BandN had about the subject was pretty weak(about 1/4in thick mainly Musclecars)
I've drooled over that kit before, but can't afford it. The wife has a 30v.
So if it will please let me know. I haven't had the SC around at a time when the the IM was off so I haven't tested the fit. It just seems like it would be alot easier this way(upside down), instead of having to bend the intake runners down and then back upgain just so I can put the SC on top.
All I'm going to say is I have a Eaton M62 mounted on a 12v V6 upsidedown over the valley pan. Its on one of the spare 12v engines I have in my garage. Already started fabrication on the custom intake manifolds, and it will be intercooled with an air/air intercooler.
The stock ECU will no longer be "involved" with engine mangagement. MegaSqurit is a programmable affordable system. The maf sensor will be removed and a map sensor does its job. A 36-1 crank ring off of a ford escort will be mounted on the 12v crank. That and a VR sensor and a ford edis6 control module and ford coil will handle the spark. All programmable. The tuning will take some time, but luckily a 4wheel dyno is supposed be opening around here soon.
