Cleaning Injectors: Is Seafoam more effective added to gas or through vacuum hose?
Old 09-10-2007, 02:38 PM
djdc's Avatar
Default Cleaning Injectors: Is Seafoam more effective added to gas or through vacuum hose?
Have a rough idle and a misfire. Put new plugs in and am awaiting some wires. But i suspect my injectors might be clogged. I would assume adding seafoam through the brake booster vacuum hose is better than adding it to the gas, in terms of how effectively it cleans the injectors, but want to get some other opinions from those who probably know more than me. TIA.
Old 09-10-2007, 02:51 PM
Evol's Avatar
Umm, running Seafoam thru the vacuum line can't clean the injectors
Old 09-10-2007, 03:24 PM
Luxus Panzer's Avatar
2nd. Put it in the gas as per instructions maybe?
Old 09-10-2007, 06:39 PM
djdc's Avatar
Default Instructions indicate either adding to oil, gas, or via vacuum hose....
that feeds all cylinders.
Old 09-10-2007, 10:19 PM
EDIGREG's Avatar
Default gotta put it in the gas in order for it to go THRU the injectors...
cleaner specifically for injectors may work better.
Old 09-11-2007, 04:20 AM
djdc's Avatar
Ok. Gotcha. Thanks.
Old 09-11-2007, 04:55 AM
Evol's Avatar
Default The trick is full can in the fuel, half can thru vacuum line, rest of can in oil.
Drive the car 50 miles, change oil.
Old 09-11-2007, 05:25 AM
CrazyCab's Avatar
50 miles, try 5 minutes at idle.
Old 09-11-2007, 06:21 AM
dowsett6's Avatar
50 miles to get it through the fuel lines, 5 minutes idle maybe if only doing the vacuum, and oil.
Old 09-11-2007, 07:17 AM
sdb90's Avatar
Default ok....I was planning on doing the seafoam too...now lemme get this.....
straight: you pour this goop in your gas tank, dump some in the valve cover and [somehow] cram the rest into a vac line????? What the hell....and HOW? this stuff really does work, right????
Quick Reply: Cleaning Injectors: Is Seafoam more effective added to gas or through vacuum hose?
