Climate control Code15.7 Air Flow Flap, sporadic block???
and everything is working fine. I checked for the code again after I confirmed that nothing was wrong and I still got the code. What's going on?
I believe that code is the temp regulator flap - sporadic block.
I dealt with that. At first it was indeed sporadic -- AC instead of head or vice versa and if I played around with the controls it would fix itself. Got worse over the next month.
I had it replaced.
I had it replaced.
as the temp regulator flap? You said you had it replaced - meaning the flap repaced or the control unit?
E_S81
Audi 100 / A6 (C4 Platform)
10-28-2006 08:48 AM
Sami Heikkinen
01-09-2006 07:20 AM
Brdman*
01-18-2003 07:32 PM
Kris Hansen
08-10-2001 05:52 AM
