coolant bleed issues...
So I am having trouble bleeding the coolant on a friend of mines 12v.
1st, let me explain how I go about bleeding the coolant. this method has worked for me dozens of times with no issues, until now...
I fill the coolant as much as I can with the upper bleeder screw open...I then(cool engine turned off) I then proceed to blow (yes with my mouth) into the coolant reservoir until all the bubbles stop coming out the upper bleeder screw, just coolant coming out. I then close the upper bleeder screw, let the car warm up..wait for T-stat to open...this usually sucks a bit more coolant in, i top up as necessary and open the upper bleeder just a pinch to let any remaining air come out.
So that being said....
I am trying to bleed the coolant on a friends 12v that just had the T-belt and W-pump done....
I do the above method, but when I blow in the coolant reservoir...air comes out the upper bleeder screw but NO coolant it drained out of the reservoir? no matter how long I blow (and I close the bleeder in between breaths to keep air form being sucked in) I can not get ANY coolant to leave the reservoir.
Same thing happens with the car running...no coolant is taken in from the reservoir???
Could there be some kind of blockage??? I am super confused.
I talked with the owner and he is not sure if the T-stat was changed with the water pump (I know, not a good idea
another thing is that the rad fans NEVER come on?? when I turn on the A/C switch the fans come on...so the fans work, but are not turned on via temperature.
Please contribute here and lets get another 12V back on the road!
P/S The heater core is good, brand new... actually bypassed for this bleed so the heater core in no way can affect the results.
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
berTTos@pjK04
02-06-2007 10:30 AM
