cylinder schematic
Try reading this. https://www.audiworld.com/forums/sho...t=firing+order
there is no picture but it explains it very well.
I need to replace coil on cylinder number 6. unfortunately those threads just tell me what cylinder is up on a timing belt replacement(#3). one thread says they "think" that the cylinder arrangement is such but i need to know for sure what cylinder is number 6 before i replace the coil. code p0306 came up and says i have a misfire on cylinder 6. i want to replace the coil on cylinder # 6 but do not know which cylinder is # 6 so hence the post to see if anyone at audiworld might be able able to help me out by just stating that cylinder # 6 is located there.
A misfire only on #6 is probably not the coil, as #1 plug is fired by the same coil (note the picture), and you didn't say cylinder #1 had a misfire. Something specific to #6, like a fouled plug, clogged injector, low compression, would be more likely.
thamka. replaced the coil pak on number 6 and my audi is humming again. great reply and good photo. you really helped me out and i saved 200 dollars.
Yes. actually my engine does not look exactly like the pic. my 03 audi a6 quattro has a 3.0 engine that has individual coil packs sitting on top of each spark plug. hence i have 6 coil packs total on the engine. ended up buying the part at rochester hills audi in michigan for $22.50 plus tax. had the code read at pep boys in sterling heights, mi for free. the local foreign car parts place wanted $47.50 for an after market part. don't know how rochester hills audi does it for less but was happy to fix my audi for for $22.50 plus tax and the time it took to replace. thanks for your help.
Although you have got your answer i think you where in the wrong forum.
This is the 12 valve V6 engine forum and you have a 30 valve V6 engine with coil per cylinder as the engine picture below.
![](http://pictureposter.audiworld.com/39444/100_0009.jpg)
Still Glad you mended your motor :-)
Moneytree26
01-04-2003 01:35 PM
Tron (///M)
Performance and Tuning
13
09-17-2002 01:13 PM
