Do anyone have an idea where the G110 coolant sensor is?
the two coolant hoses that run behind the engine. They are two sensors (although one is called a switch). If you're thinking about replacing them I'd recommend doing both. Don't forget to change them when the car is cold.
That is the weird thing, I replaced both sensors behind the engine, the tempsender and the G62 sensor. But vag-com says a g110 sensor is broken, or a short to B+. but when I check the coolant temperature on the cc system, it shows the engine coolant temp just climbing to 90deg even when the car is switched off..
The Crapple
Audi Original "S" Cars
15
07-13-2006 03:13 PM
jason in toronto
05-30-2002 05:08 PM
