does a new valve cover gasket need any sealant
<center><img src="http://pictureposter.audiworld.com/61186/gasket.jpg"></center><p>are you talking about these parts of the gasket or somewhere else
really close by the spots where you are supposed to use a dabs of RTV. The openings are rectangular and very small. If you look close, you can't miss them.
<img src="http://i4.photobucket.com/albums/y108/moribundman/oil_passages.jpg" alt="Image hosted by Photobucket.com">
can the head be remove without disecting the cam shaft..
what type of oil or cleaner do you use
Naturally, the TB has to come out.
No cleaner was used. That's how it looked with the valve cover removed before I cleaned the gasket mating surfaces. The valve cover gasket had been leaking. That's at ca 122k miles. I had been using Castrol Syntec 5W-50 and 10k milke oil change intervals for the previous 100k miles. I expect the engine uppers to look even cleaner now that I'm using M1 5W-40, which has better cleaning properties than the Syntec. I'll soon now, because I will take the valve covers off again.
Mine is black and filled with flakes like a box of kellogs cereal, I could not even see the oil holes and had to dig the gum out of them..
I affaid to start the car after I'm all done with all the flakes I scraped off..
by the way any idea how to remove the bolts from the crank pulley, I'm about to grind them off since the last three are starting to round out..
BikerBill
02-09-2012 03:28 PM
MYTTS
07-24-2006 06:06 PM
SantorinSteve
10-01-2004 09:50 PM
Bobby Kinstle
12-27-2003 01:07 PM
