egr solenoid valve
1998 avant v-6,engine chugs after revving & back to idle,remove line at egr valve & idles smooth,apply vac at valve with pump & egr opens & closes fine,have cleaned out port in intake,tried 2 different (used) egr solenoid valves.remove line at egr valve,install vac gauge,rev engine & have vac, then vac will not bleed back off, this is what is causing idle issue,when revving engine vac is staying applied to egr causing idle chug.remove line & idles fine again.have been driving with line plugged off at egr, then runs fine
Your lack of responses may be indicative of how difficult your post is to read. A little editing might help. Break it up into 2 or 3 sentences. If you're trying to illicit a response from an adult, take the time to write with that audience in mind. There are some very clever people writing here, make it easier for them to understand exactly what you have observed, what you have done and what you would like help with. This is my 6th sentence, each one has a point and my response is still shorter than your too long of a sentence.
https://www.audiworld.com/forums/sho...highlight=ruin
Hth
Lago
Hth
Lago
kday
Audi 100 / A6 (C4 Platform)
01-15-2007 04:30 PM
reefer_bob
07-01-2006 09:34 PM
Vurtrue
08-07-2003 08:07 PM
