Engine check-up
Hey guys
So i have had my 12v for about 7 years now. I've never changed or done anything with the engine yet. Even the air filter is still the same.
The engine has around 190k on it now. As i can understand, there is a lot to gain by just getting so close to OEM condition as possible.
Which things should i check, and what should i definately do by now? I don't experience anything odd. Idle is fine, and i get around 21MPG with mostly freeway driving (85mph).
Vacuum hoses, spark plugs, filters? Anything else?
air filter
fuel filter
spark plugs
spark plug wires
Coolant flush (G12 coolant)
Oil Change
T-belt
i would also consider changing the transmission and rear diff fluids
fuel filter
spark plugs
spark plug wires
Oil Change
T-belt
I totaly forgot, i actually had my timing belt + water pump changed 10k miles ago. But other than that, i haven't done anything.
Any particular spark plugs recommended?
NGK!!!!!!!!!
i would recommend running seafoam thru the fuel, engine oil and intake ;-) and do it outside and warn the neighbors so that they dont call a fire department on you
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
giuseppepat
09-02-2015 02:47 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
