Engine Coolant Temp Sensor Replacement - Part 3, and getting better!
#21
Maybe I'm just unfamiliar with protocal but I figured it wasn't cool to just start hammering a guy with emails about how to do something. I wanted to let the forum posting process run it's course. In the future, do you mind if I email you directly? I've never done this before...
#22
but I'm amazed that anyone who saw the pic you'veposted wouldn't recommend just clearing a path instead of digging thru it. Even if no ones done one it's easy to see you're working thru some easlily removeable spaghetti. And I'd never replaced one til I replaced mine but I could easily see doing this without removing some stuff would be like changing a piston thru the throttle body.
I don't read/check "every" post as some don't interest me. But I stumbled upon your's by it's number of responses. I thought you'd been well-handled due to the sheer numbers. Somtimes that will spark an interest and I have to go in, see what all the hooplah is about.
I do get a LOT of emails so try my name in a post first. Then we'll take it private if necessary/appropriate.
#23
ever! It's SO not necessary, intrusive, presumptuous and not AA's nature. Just doesn't suit him... AT ALL.
#24
Get rid of that stock plenum for less restriction, which equals more power. Also enjoy ease of access to engine components without the plenum being in the way all the time.
#26
then I will need some guidance, not convincing. That's what I meant. Do you mind telling me why I might want to install that item, where it goes, how to reattach all the tubing that mounts to the top of the OEM item (or does it?), etc. I'm a sucker for modding/tuning but can only get excited when I feel educated. Thanks!
#27
and accordian hose. It's 3" silicone hose that runs from the MAF directly into the throttle body and the one pictured also has the optional crankcase breather sleeve (the smaller hoses in the pic which run to the valve covers).
