for everyone who is running a cone..
Where did you find you MAF adapter? i bought the one off eBay a long time a go and it never fit right.. always lop sided and blocking off the full potential of my intake... i went back to stock air box with fram filter and some holes drilled in the bottoms and side.. it runs alot quieter kinda liked it but under full bore or any other it just doesn't compare.. seems like the car is gasping for air.. so i want to get an S&B huge filter and a nice fitting MAF adapter.. hit me with your replies.
thanks
dustin.
thanks
dustin.
however I encountered the same problem as you. I bought an adapter from autozone and adapted it to fit the bolt holes on the MAF- and it was the most off-centered, horrible-flowing thing I have ever seen (theres no way I would have shown the outside of this thing to any of you guys, much less the abominable hack of an inside).Anyways, to solve my problem, I got some aluminum pipe of the same diameter and a scrap piece of plate aluminum and [since I havent welding skills as of yet] I had a shop make one for me.....at an outragious cost of course, but the thing lokks friggin sweet and flows amazing
i went outside to fit the cone onto the MAF and it doesn't fit because they are both 3in.. so the cone has to be a lil bigger.. so im just going to order a whole new nice filter.
and the ID of the filter inlet. Your talking just under a half an inch!!! I dont know man, maybe I'm not picturing this right in my head, but It doesnt seem to be a good idea, especially since you now have a spare maf which is no good to you anyways-hehehe. right?
WHERE?? are you going to "slap a 3.5" inlet cone on there"....without an adapter? were you going to somehow s...t..r..et...c..h the filter inlet over the huge-***, square end of the MAF with the bolt holes (for the stock air box....or.adapter)
The only side you could just put a filter on is the side that goes to the boot/throttle-body/manifold/etc.
explain please, cuz now my brain hurts
