FAILED IAC valve (more commonly known as the Idle Stabilizer Valve, or ISV) HELP
My car was jump started last night and since then the car's RPM holds around 1600rpm
You can hear that the IAC is stuck open.... things havnt changed and its now the next day.
Has anyone had this issue?
ive done a VAGCOM scan and no errors are shown sadly can you run a scan with the car running?
ive called audiwreck in Oakleigh and the said it should stop doing it while drivin... But ive driven it time and time again for around an 40mins and sadly no deal.
I really dont want to pay a mechanic to ripp me a new1
its freakin me out... Please help
cheers case
cheers case
I don't think jump starting has to do anything with a stuck ISV.
First check the solenoid with a DMM, you can do it on the car just by removing the cables. If it looks good, remove and clean it. There are plenty of instructions on how to do it. Here is one of them:
http://12v.org/maintenance/repairs/isv.php
You can also do a VAGCOM test to cycle on-off the valve. It makes a loud clicking sound as it opens and closes.
cheers case
cheers case
Kareem of Elise
11-22-2006 11:01 PM
