gear puller?
gear puller?
What size gear puller is appropriate to pop loose the camshaft sprocket and the TB sprocket on the crank? I Picked up a 6", it seems to big though. Should a 4", 2 ton?, be able to handle both of these sprockets?
From Zelenda
<center><img src="http://www.zelenda.com/VW/T40001.jpg"></center><p>T40001<ul><li><a href="http://www.zelenda.com/VW/EngineTools4.html">http://www.zelenda.com/VW/EngineTools4.html</a</li></ul>
Re: cheaper solution
<center><img src="http://content.sears.com/data/product_images/009/46905/00946905000-190.jpg"></center><p>I've used these, but cut off enough of the turn screw, so it would not longer hit the car.
Plus set'm up so the bolts are in the bottom holes of the puller arms.
I had to also use a Vise-grip chain wrench, to hold the arms of the puller together. To keep the puller from slipping off the cam sprocket.
