got these codes pulled off my computer...
hey guys i just got these codes pulled off my computer...can anyone explain to me what they mean...thanks
P1510
P1101
P0150
P0130
P1106
P1409
P1400
P1204
P1201
P1206
P1205
P1343
can someone help me with these please...thank you
P1510
P1101
P0150
P0130
P1106
P1409
P1400
P1204
P1201
P1206
P1205
P1343
P1510:
idle air control circuit, short to B+
P1101:
O2 sensor low voltage, pre-cat sensor (bank 1)
P0150: O2 sensor low voltage, pre-cat sensor (bank 2)
P0130:
O2 sensor malfunction, pre-cat sensor (bank 1)
P1106:
P1409:
fuel tank valve electricl malfunction
P1400:
EGR valve circuit malfunction
P1204:
fuel injector circuit electric malfunction (cylinder #4)
P1201:
fuel injector circuit electric malfunction (cylinder #1)
P1206:
fuel injector circuit electric malfunction (cylinder #6)
P1205:
fuel injector circuit electric malfunction (cylinder #5)
P1343:
ignition coil power output stage 2, short to ground
P1101:
P0130:
P1106:
P1409:
P1400:
P1204:
P1201:
P1206:
P1205:
P1343:
17918 P1510 Idle Air Control Circ. Short to B+
17509 P1101 O2 Sensor Circ.,Bank1-Sensor1Voltage too Low/Air Leak
16534 P0150 O2 Sensor Circ.,Bank2-Sensor1 Malfunction
16514 P0130 O2 Sensor Circ.,Bank1-Sensor1 Malfunction
17514 P1106 O2 Sensor Circ.,Bank2-Sensor1 Voltage too Low/Air Leak
17817 P1409 Tank Ventilation Valve Circ. Electrical Malfunction
17808 P1400 EGR Valve Circ Electrical Malfunction
17612 P1204 Cyl.4-Fuel Inj.Circ. Electrical Malfunction
17609 P1201 Cyl.1-Fuel Inj.Circ. Electrical Malfunction
17614 P1206 Cyl.6-Fuel Inj.Circ. Electrical Malfunction
17613 P1205 Cyl.5-Fuel Inj.Circ. Electrical Malfunction
17751 P1343 Ignition Coil Power Output Stage 2 Short to Ground<ul><li><a href="http://ffp-motorsport.com/tuning/odb2.php">Link</a></li></ul>
Did someone work on yor car? Is it actually running? It almost looks like a bunch of wires has been disconnected or shorted out or something. Or maybe the ECU is on the fritz?
well i had my local mechanic hook up the computer to the car to see if any code popped up...and that's what he gave me...everything runs completely fine...only thing i notice from driving it for three years is a little power loss...not too much...and it drinks...lol...i had the mechanic clear the all codes...and I'm going to go back there 2morrow and see if these codes pop back up again...if they do...then i have a problem...oh...and my check engine light doesn't go on...even with these codes...people tell that it's supposed to go on...thanks for your help guys...
.. and the CEL would definitely come on. Looks more like technical difficulties with reading the codes properly.
Avdwaal1
24
08-22-2016 10:54 PM
g1power
05-31-2009 03:45 PM
KgS4
05-31-2005 12:33 PM
mike*green
07-21-2004 03:35 AM
