Head Gasket
Head Gasket
ok well car was in shop today to look for oil leak and being told they beleave it to be my head gasket. Maybe vally pan gasket but they wrote it up at worse case. So $1500.00 to change out both head gaskets I am being told .
How bad is it leaking?
It may well be that the head gaskets are moist and that you are losing a bit oil there. My engine has been doing that for 80k miles or so. I'm probably going to retorque the headbolts next time I remove the intake manifold to replace the leaky valley pan gasket. Personally, I would want to see with my own eyes where the oil is leaking. Chances are the VP gasket is leaking in any case. Removing the IM and replacing the VP gasket isn't that bad of a job to do yourself. Cost is essentially only the VP gasket and the two IM gaskets.
You will need a few hours
Outside is fine, unless it's windy, raining, or very hot or cold.
<a href="https://forums.audiworld.com/12v/msgs/4105.phtml">Intake Manifold Removal and Valley Pan Gasket Replacement</a>
iVTEC Yo(ex-B5er)
12v V6 Discussion
02-28-2006 03:24 PM
tk1780
Audi 100 / A6 (C4 Platform)
02-01-2006 07:47 PM
yooper
06-23-2005 09:42 AM
