Hey guys, I finally got my CEL codes read. please help...
I have no clue what this means or what to do about it but heres the code:
#16706 - Engine speed sensor
G28 No signal
P0322-72-00 Cylinder 5
I did a search and found this.. still dont know what to do
16706 P0322 Ignition/Distributor Engine Speed Input Circuit - No Signal� A or B / Blink
G28 No signal
It senses engine speed by the teeth on the ring gear. There are a number of possible causes of the fault code: a loose sensor mounting bracket, metal chips on the sensor (from the ring gear), bad ground connection, too great of a distance between sensor & ring gear, faulty sensor, and/or open circuit in wiring. To fix the problem, you should really have access to a Bentley Repair Manual.
agrandy
06-09-2008 05:26 AM
BigMouse
04-21-2006 07:01 AM
Mitaka
02-07-2005 10:13 AM
