IAC valve fit problem. My IAC was bad and the replacement
is a different style but same part number. The original has left an impression in the flange it mounts to. The replacement is not sealing properly against flange and leaking a lot of air into the intake.
Any ideas how to fix this short of getting a new flange? I was thinking of heating the flange and then mounting the new valve. The flange seems to be made of a very hard rubber. I am not thinking silicone because I would not like it if it got sucked into the intake or fowled up this valve.
and replaced the valve. The leak has improved quite a bit, but I still hear some hissing.
a4_1.8t_01
04-20-2021 11:23 AM
For those that have bypassed their N249 valve.. what did you use to cap off the line from the valve?
Lightweight-USPowah
Performance and Tuning
09-23-2003 12:18 PM
