I'm Audi 5000 - TB that is
The Audi 5000 Big Bore TB fits the 12v intake manifold like a glove. Some minor modifications are required but nothing extreme. I've been running it since June with no issues. Makes for an easy upgrade for those who would like a little more room to breath! No honing, boring, epoxy, etc needed.
ok, so im holdin 3 TB's in my gand right now, first of all, how did u mod the TPS to mount, 2nd what did u do with ISV passages? they will bolt on, but i dont c a way to mod those 2 things
You are also correct that the ISV inlet passage will not line up. This will be bypassed. Cap off any unused vacum ports and turn the idle screw on the 5k TB all the way in as to close it off. The car will run if you just bolt it on as is and supply air via the idle screw. Essentially this eliminates the ISV. This will make for hard cold starts and best results are had by creating a proper bypass route to allow the ISV to function properly.
I'll have to create a second post with pics describing how to bypass the ISV. I'm not at my computer now so can't upload them. It will be easier to follow with visual aids.
What i can tell you is that the intake manifold will need to come off. So it is also a good time to port match, clean up your intake, and replace the gaskets if you haven't done so already, and if you have already then even better, you are already familiar with the intake and should be able to do the job quickly.
More to come
To bypass the ISV passage you need to pull the intake manifold. Once you have removed it. Flip it over and drill a 7/16" hole into the ISV passage on the intake manifold at the red spot shown in the picture below. This hole can then be threaded with a 1/4-18 NPT tap. Purchase a Hose Barb Fitting, Male; 3/8"; 1/4" NPT(Found at NAPA) Once you have drilled and tapped the hole wrap the threads on the hose barb with some Teflon tape and thread it in. You have now completed the intake manifold. Now to supply air to the ISV via this new bypass you need to purchase some 3/8 hose and run a line from your air intake. This procedure may vary from person to person depending on your current setup, but the general idea is to thread another 3/8 hose barb into your current air intake setup (after the MAF) and use the rubber hose to supply air from that point to the ISV, bypassing the TB ISV passage. I personally fabricated new aluminum intake piping using some mandrel bent elbows and fitted it with hose barbs that were welded flush to the piping to support the ISV bypass and the breather hoses from the valve covers. I then used a rubber cobra head elbow to clear the firewall and connect my air intake to the TB. I was able to maintain my stock engine covers and appearance. Like I said, I have been running this setup now for about 5 months with no issues. This modification is by no means a direct bolt on. However, I think it is an easy option for those DIY'ers out there looking to run a larger TB at an economical price. All it will cost you is a junkyard 5k TB, intake gaskets, 3/8 hose barbs, 3/8 hose, and time.
mrprism133
10-01-2015 05:51 AM
wood_e
12v V6 Discussion
12
02-15-2007 11:09 AM
Afterthought
13
10-30-2005 11:45 AM
ACerr22
10
10-06-2002 10:18 PM
