Initial 034 12v chipsets, details inside:
Old 05-13-2008, 02:51 PM
  #11
Former Vendor
nate @ 034MOTORSPORT's Avatar
Default Not on the 311 at this point
As I meantioned before though, those that want to start mixing it up who have 311 ECU's can retrofit the earlier systems very easily. The only thing different between them functionally is the lack of a CO adjustment POT on the MAF. And get the added side-benifit of a 400RPM higher rev-limiter.
We were testing the car here with MMS200 to MMS311 back to back with no wiring changes. Since the car came with a MMS200 setup it's already got the CO POT wiring, the 311 ECU simply ignores that pin, so it's a direct swap.
Old 05-13-2008, 03:31 PM
  #12
Junior Member
Slye A4's Avatar
hire a few interns. ;p
Old 05-13-2008, 03:38 PM
  #13
95ninety's Avatar
Default Sorry to be slow, but not very savvy on ecu stuff...
SO you are saying that my car, with the 311 ecu, can use the older 200 ecu with no changes, and get the 6700 rev limiter with no drawbacks?
Sorry for dumb question =)
Old 05-13-2008, 03:44 PM
  #14
Former Vendor
Default Yes, provided you have proper programming in it for your MAF.
So a bone-stock, non-chipped MMS-200 ECU wouldn't be a very good candidate, unless you reverted back to the smaller MAF.
With the 1+ chipset and the MMS-200 ECU you'd be good to go, and net a higher rev-limiter.
Old 05-13-2008, 03:48 PM
  #15
95ninety's Avatar
Default Ok sorry, that's what I meant.....
So with your stage 1+ mms200 ecu and my bored out maf would make a good combo in my 95 mms311 car? =)
Old 05-13-2008, 03:56 PM
  #16
Former Vendor
You got it
Old 05-13-2008, 03:58 PM
  #17
Mr Dobey's Avatar
Default So this whole ordeal would be an entirely different story if I brought my car in?
Considering it's a 1996 A4 with a newer ECU?
Old 05-13-2008, 04:00 PM
  #18
95ninety's Avatar
Default When is it available?
Need to find a mms200 ecu (yikes)
Old 05-13-2008, 04:54 PM
  #19
Junior Member
Slye A4's Avatar
so for an A4, you buy the mms200 and the tuning and you get 10hp/tq and 500more rpm?
Old 05-13-2008, 05:08 PM
  #20
Former Vendor
Default A4 uses the 411 ECU with an additional connector, haven't tested/verified the wiring on that ECU
May work with some minor mods, but you'd lose the OBD-II abilities for sure.
Quick Reply: Initial 034 12v chipsets, details inside:
