injection
What mods do you have?
You may find it better to use 30v injectors which have four holes versus our OEM 2 hole injectors.
However, I have found that using the SplitSecond ARC-2's throttle adjustment helps a great deal regarding the lag associated with the OEM injectors. While it cannot do the same job of 200 cc injectors at max RPM, it does quite well at lower RPMs while retaining much of the OEM mileage. The ARC-2 proves a wonderful addition for those who like to micromanage their air fuel ratios. Otherwise, use larger injectors with an adjustible fuel pressure regulator.
porsches4ed (APR S3)
02-17-2005 10:10 AM
AlwaysAudi
12v V6 Discussion
16
02-03-2005 02:52 AM
