intake
intake
so i just went to u pull it and got myself a nice used maf now to turn this to a maf adapter i would do what exactly? i've read the threads but just wanna be safe and see if any one will post some nice easy directions. also any suggestions for diy heat shields?
Re: intake
<center><img src="http://pictureposter.audiworld.com/84566/maf_adapter.jpg"></center><p>The pic is a cut down MAF used as a cone filter adapter. It has about 2", maybe a little more, between the flange and the cut.
You can use a small bore MAF sensor to make a cone filter adapter
<center><img src="http://pictureposter.audiworld.com/76266/maf.1.jpg"></center><p>Just cut where I marked the red line. Then use a dremel to smooth down the "red" section on the right side of the pic. I don't remember what the O.D. of that MAF is but measure it and buy the appropriate size cone filter.
