Misfire problem.
Old 05-26-2006, 05:30 AM
New Member
Barty's Avatar
Default Misfire problem.
OK, here is one for you to test your automotive mechanic skills.
Car is hesitating (misfiring) pretty bad especially during warmer weather and when the engine warms up. The ECU registers Cyliner #4 misfire. All plugs and wires were replaced with new. Wire resistances and coil output resistances seems consistent between cylider pairs. As you know this system uses waste spark method meaning 3 coils. When VAGing the car during driving I recorded cyl #4 misfire and occasional misfire #5 (although very rare on 5).
Any other diagnostics that I can do before I attack the injector for #4 cylinder? If the coil was bad wouldn't I get misfire on a pair of cylinders due to the waste spark aggangements?
Any tips of the trade would be much appreciated. Any way to test injectors with VAG-COM?
Thanks as always.
Old 05-26-2006, 12:43 PM
moribundman's Avatar
Default Check the wires that go from the power output stage (ignition amplifier) to the ignition coils
The wiring runs under the intake manifold (on my '96 A4).
I had this problem, so maybe you have the same issue: Eventually the wire insulation rubbed through, causing misfire like you described. This happened especially in wet weather. Ultimately, a few miles later, one of the dual coils shorted out. Although the time from the first symptom to coil failure was very short, the insulation, judging by the amount of deterioration and corrosion of bare wire, must have been compromised for at least thousands of miles.
Of course, it could be just a bad spark plug.
Old 05-27-2006, 05:44 PM
New Member
ringsX4's Avatar
Default Re: Misfire problem.
maybe we can combine some knowledge here. i got a 96 cabriolet 12v v6 with engine light on due to misfires. came in with faults stored for #4 and #6 although #6 seems to be the one that keeps returning. it has rough idle. new wires, swapped plugs which are also pretty new, i also checked the egr and thats working good. i unplugged the idle stabilizer and the idle did not change so that was gonna be my next step.(remove and clean) i know its working electrically(output diag with vag-com) i was also thinking of swapping injectors. I thought there was a recall on the fuel rails on those 12v engines but it didnt apply to mine so no luck there but maybe you should check that
beachcomber
14
07-26-2021 05:08 AM
amdreamer1
05-08-2019 09:01 AM
brandonb93
A4 (B7 Platform) Discussion
12
12-04-2018 01:16 PM
iamdrewseph
10-01-2015 11:33 AM
smiladon
10-01-2015 01:31 AM
Quick Reply: Misfire problem.
