My roommate borrowed my car and put regular instead of premium gas in there. Can I just put...
octane booster in the car and call it good? I had just under half a tank and he put about 4 gallons in. I got VP Octane Power Boost because it had the highest increase of 6 points. Can I just fill it up the rest of the way with premium? Thanks a lot.
The only effect of the slightly lower octane is bad fuel mileage. I'm at sea level, and even 87 octane didn't make my car ping. I wouldn't waste money on octane booster. It might foul your plugs.
Yeah the bottle says it might cause damage to O2 sensors and cats. So I was reluctant to use it. Glad I asked you guys first. How does the booster foul up your plugs?
can leave ash behind on the plugs. I've experienced that first-hand. Someone correct me please, but I think ash is usually due to metallic additves.
All those fuel system cleaners are strong solvents, they don't clog anything, and they do clean as promised, at least more or less. But when small quantities combust, you may get residue from the cleaner's additives on the plugs. I would recommend using a fuel system or injector cleaner two tanks before an oil change. Changing the plugs doesn't hurt either, but is not necessary. You may run into problems if you use too many fuel additives.
I thought as long as its unleaded there is no difference. I know premium is filtered better but I didnt think to that extent. When I've been dumb enough to drive home with the gas icon on my dash I have used regular gas that I keep in tanks for my lawnmowers and other gas powered tools to fill up my tank. I dont notice any difference at all. Is the 2 times a year you put regular in your car that big a deal?
PS: I dont mean I'm right, I myself dont know. There should have been some more question marks in there.
the ECU is compensating for lower octane fuel. If the ECU can't compensate anymore (at high temperatures, at high load), pinging will occur and engine damage can result eventually. 87 octane fuel hasn't caused a problem in my car when I used it a few times (they were out of Premium), but gas mileage went down, so there was no savings at all. I do believe in using quality 91 octane gas (not Ray's) in our motors.
Sorry about all the questions, I really appreciate how grateful all of you are with your vast ammount of knowledge. Even though it's off topic; Mance enjoy a nice beer tonight, I'd never try to bash you or your knowledge
