need a favor of someone who has time.....
tell me the exact part number of your instrument cluster on your A4. I would assume all 96's are the same, but I look on ETKA and their are 3 different versions, plus Canadian versions.
Who knows a lot about these clusters? Can I put a 98 in my 96 seeing that it would be newer, hopefully less mileage on it?
don't know what year it started to have new plugs but i do know all the S4s have different plugs....so u will need the wiring harness from the newer cluster to hook it up properly
My '96 has the VDO cluster with the Mini-Check system, but I don't have the part number. I've had teh cluster out, but I don't recall how many plugs there were on the back.
My repair manual shows that the cluster with the FIS display (trip computer etc) has two big plugs and one slightly smaller one.
I don't know if that helps at all. :-\
it should work.
But that would make sense. :-/
Do you need me to look anything up in ETKA?
I think they only came on the 96-97 models. I've read you can switch from the Nippon model to the VDO model which is better I guess, but don't know what the visual differences are.
The Nippon Seiki uses little red rubber condoms on the bulbs, the VDO doesn't. I don't know if the VDO and Seiki clusters are otherwise identical. I would think they are the same, as long as neither one has the trip computer. I'll see if I can find a picture.
Audi Other 2013 Audi S6
S4_Next
09-26-2015 04:27 AM
SP767
10-13-2000 09:17 AM
Rhema
08-29-2000 10:49 PM
Doug
09-13-1999 01:16 PM
