NEED HELP FOR CD CHANGER
HELLO,
I HAVE 1997 AUDI A6 QUATTRO AND DELTA CC RADIO WITH 8 PIN DIN CABLE IN TRUNK. I FOUND ALPINE 6-CD CHANGER (CHM-S630) WITH 8 PIN DIN CABLE. THIS CD CHANGER WILL WORK WITH MY DELTA CC RADIO.
ANY HELP?
THANKS
MUKESHKUMAR PATEL
ANY HELP?
THANKS
MUKESHKUMAR PATEL
THe only aftermarket that will work plug & play is panasonic 8 disc CD changer for audi symphony.
They both have 8 pins but they have different configuration of pins. However you can modify the cable if you know which one is which. That's just my opinion.
it's the correct type of connection. It's a wierd protocol called m-bus. Check E-bay there are usually some for sale to see if anyone has a similar part number. They were used on all audi's thru 97.The head unit is Bosch (blaupunkt) See if you can try the unit before you buy.
GJV
10
12-28-2006 07:38 AM
shwndh
07-13-2005 12:19 PM
