New Magnaflow 2-into-1 3" Hi-Flow cat with 2.5" exhaust system installed
Old 08-13-2003, 07:02 AM
  #21
Black Sunshine's Avatar
Default Mine has a bit of raspiness when it's cold... then it goes away
and sounds great across the board.
The burble/backfire sounds is sometimes associated by a metallic crackling sound, which is wierd.
I wonder what else contributes to the sound an exhaust makes...
  #22
Elder Member
Dead's Avatar
IIRC from looking at the ETKA ,FWD uses a single cat.
Old 08-13-2003, 07:05 AM
  #23
Elder Member
Dead's Avatar
Default Sounds of a hot vs cold system will be a lot different between stainless and non stainless systems.
To one degree or another everything about the system(diameter,bends,type of metal,type of joints,type and placement of components,....etc.) effects the noise it makes.
Old 08-13-2003, 07:14 AM
  #24
Default But is there anything else that can come into play with sound???
As in maybe cleanliness of the exhaust manifold??
I don't know I'm just shooting into the dark in an effort to find that balance point between performance and a non-obtrusive sound.
Old 08-13-2003, 07:15 AM
  #25
VAP
VAP's Avatar
Default I wanted the original prototype to be welded. When I go back and re-do it in stainless...
after the bugs are worked out it will have downpipe flanges and a flange at the end of the long straight so it can be removed in 2 sections.
Old 08-13-2003, 07:57 AM
  #26
Why 1 cat?? and why a 3" one???
Old 08-13-2003, 10:25 AM
  #27
VAP
VAP's Avatar
weight, efficiency, replacement costs and half the potential of cat-related issues
Old 08-13-2003, 11:33 AM
  #28
MM120's Avatar
Default My FWD has two (unfortunately)
I wish it had none.
Old 08-13-2003, 04:28 PM
  #29
520
520's Avatar
Default Try here, really cheap!
<ul><li><a href="http://www.firstchoiceautoparts.com">http://www.firstchoiceautoparts.com</a</li></ul>
Old 08-13-2003, 04:59 PM
  #30
scott12v@pghaudi's Avatar
Thanks...I'll check it out.
Quick Reply: New Magnaflow 2-into-1 3" Hi-Flow cat with 2.5" exhaust system installed
