performance chip
I have done almost all of Mance's mods on my 12v.
Following is a dated list of them:
7/24/03 - Installed Mance's Cold Air Induction System & Velocity Stack (also took out MAF screen). Seems to have more power between shifts, revs easier, and more power in the upper RPM ranges.
9/13/03 - Installed Mance's Stage 3 MAF & Stage 2 Hose Kit. Better RPM response and seems to be louder. That slight hesitation also seems to be smaller at the shift points.
12/7/03 - Rebuilt heads, ported & polished and match port all gaskets to heads(both intake and exhaust). Installed A/C Delco Rapid Fire #9's.
3/22/04 - Just purchased a used TB for a 1995 A6Q AT from Pam's Auto in MN for $75.00. I will send this in to Mance as a core charge to purchase the XTB `Special TB': 707 CFM.
Part # B5 048 078 063P.
3/26/04 - Replaced regular VS with Stage 3 Velocity Stack (S3 VS).
4/8/04 - Installed Mance's rubber O-Ring in the orifice of the S3 MAF (I put in the largest diameter as per his instructions).
8/6/04-Ported and polished my Intake Manifold, had it installed along with the XTB `Special TB'
My own estimate on the HP gains would be somewhere between 25-50.
4/8/05 - Solid Strut Mounts installed.
7/9/05 - Generation 2 Strut Bar & Solid Strut Dust Caps.
Mance is your best bet on mods for the 12v. He sells direct via his email.
Hope this gives you some idea of what is available.
All pictures and documents are property of Mance of course.
<a href="http://dgreg.phpwebhosting.com/audi/imworkshop">http://dgreg.phpwebhosting.com/audi/imworkshop</a>
I deleted my Word Documents as I completed the entire process.
Now I have them back.
Thanks again.
Here's a shot of my IM:
<img src="http://pictureposter.audiworld.com/81050/img_0020.jpg">
Thanks again.
