Testing an MAF....
mass air flow rate should be 80% of your rated HP. For example, 150 HP x .80 = 120 grams/sec air. To do this, plug VAG-COM into the OBD-II connector (assuming you have '96 or newer car), and then take it out on a freeway and run it wide open in second gear while recording the mass air flow rate. Then check the values recorded. VAG-COM stores its data in CSV files that you can read w/ MS Excel. PLot the air flow vs. RPM - it should be linearly increasing w/ increased RPMs. If not, then your MAF is bad.
iestatic
S4 (B8 Platform) Discussion
20
07-15-2022 09:43 PM
audiinnj
A4 (B8 Platform) Discussion
9
12-05-2018 04:31 AM
BriGuy01-2.7T
37
10-22-2015 08:04 AM
danfil
09-19-2015 06:32 PM
